Clutch Replacement
  • PrinceE30
    • 282
    Clutch Replacement
    I'm checking through BMA auto parts and trying to figure out exactly what I need to replace the clutch on my 1991 318is. I'm probably going to replace the flywheel as well (VAC probably). So...who can give me the 411 on this?
    -Prince
    Randall Prince
    http://www.rp1.us/ Used Cars
  • Dave
    E30 RAT
    • 11675
    If you are going to go to BMA, call them, ask for Patrick. They will set you up with what you need. If you are going to be in there, might as well do the rear main seal and consider doing the tranny seals as well. Consider whehter the guibo and CSB might need replacing as well.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • PrinceE30
      • 282
      What's the CSB?
      -Prince
      Randall Prince
      • Alecs MacDonald
        • 729
        Originally posted by PrinceE30
        What's the CSB?
        -Prince
        Central support bearing.
        '88 325ic
        • Digitalwave
          is a poseur
          • 6298
          Clutch kit (pressure plate, clutch disc, throwout bearing)
          Pilot bearing
          rear main seal
          tranny output seal
          tranny input seal
          clutch release fork
          clutch slave cylinder
          pressure plate bolts
          clutch fork spring
          clutch alignment tool
          Redline MTL
          guibo (flex disc)
          center support bearing
          resurface or replace flywheel
          good time to replace reverse light switch if yours isn't working
          RISING EDGE
          • PrinceE30
            • 282
            Thanks TJ!!!
            -Prince
            Randall Prince
            • Brew
              • 3060
              rear main seal
              tranny output seal
              tranny input seal
              clutch release fork
              clutch fork spring
              guibo (flex disc)
              Just to clarify TJ's post, this stuff isn't really necessary. Obviously replace the seals if they are leaking, replace the guibo if its cracked. I wouldn't replace the slave as preventative maintenance, its easy enough to do if/when it fails. Its not necessary to replace the pressure plate bolts, but you should use new flywheel bolts. You should torque the flywheel and pressure plate bolts. You may also want to replace the clutch fork pivot if it is worn. And don't forget to grease the pivot points on the fork.
              '91 318is
              • RobertK
                Kicked cancer's ASS.
                • Jun 2005
                • 5864
                As far as the Guibo is concerned, if it's not cracked just let it sit in some motor oil overnight or for a few days. Makes it look and feel as if it were brand new.
                • Digitalwave
                  is a poseur
                  • 6298
                  I meant flywheel bolts, not pressure plate. My bad.
                  RISING EDGE
