5spd swap pedal question
  • Sagaris
    • Sep 2009
    • 2243
    I have an airbag car and it appears that the manual pedal box I have for the swap is from a non-airbag car (since it has that compression spring for the clutch that pivots at half-travel). I plan on just swapping pedals, not pedal boxes.
    RealOEM shows the airbag and non-airbag brake pedals are the same part number, but the clutch pedals are a different part number (for the obvious reason that the return spring provisions are different).
    Searching around shows that running without a clutch return spring is fine, and I am okay with that. What I am wondering then, is if anyone has ever used the non-airbag clutch pedal with an airbag pedal box (forget the return spring, I am just concerned with the pedal itself fitting and connecting properly). I cant imagine there would be any issues but one has to wonder.
    I have noticed on another car I had, that there was an adjustable eccentric for the connection between the clutch pedal and the clutch master cylinder, and this non-airbag pedal box does not have that. Just an observation, hoping that someone can come right in here and say that they have tackled this exact situation without needing an airbag brake pedal and eccentric.
  • davem
    • Jun 2010
    • 705
    My car is an airbag with five speed swap and non-airbag clutch pedal.
    • Sagaris
      • Sep 2009
      • 2243
      Thank you for confirming this. Just curious, are you running any sort of return spring?
      Also does your car have the adjustable eccentric at the clutch pedal to clutch master cylinder connection, or is it just a regular bolted connection?
      • scottinAZ
        • Dec 2009
        • 1312
        at some point they went from a steel clutch pedal to a plastic one. Not sure of the date, but that would account for the difference in part numbers. Spring is not truly needed, so that would be a non-issue
        I saved 15% on my Bimmer parts by switching to ...
          • 37834
          On my old 1990 325i I did a 5 speed swap. I left the airbag pedal box installed and only swapped the actual pedals. The pedals I used were from an 87 so they were they metal style. I did not use a clutch return spring and the car drove perfectly.
          Grover Beach, California
          BimmerHeads.com
          • Sagaris
            • Sep 2009
            • 2243
            Thanks for the responses!
            • WhyNot
              • May 2012
              • 363
              I have a 1991 Vert 5 speed.
              It is an airbag car.
              It has a plastic clutch pedal.
              I want to change out the plastic cutch pedal with a metal one.
              I will be leaving/using the original clutch assemble box that came in the car.
              I will only be switching out the clutch pedal itself.
              This post
              says that need a special bolt is needed, part #4, and locknut #5
              http://www.realoem.com/bmw/showparts...04&hg=21&fg=10
              This post http://www.r3vlimited.com/board/show...l+clutch+pedal
              says that
              >airbag models have airbag pedal box
              >later models had plastic clutch petals and a different box
              >early models have metal ones
              >early model ones are prone to cracking along the side of the stamped support bracket.
              So what I'm trying to verify, before I dive into changing the plastic pedal to metal pedal....
              1.The plastic pedal is weak and should be changed to a metal one. Correct?
              2.To switch from plastic to steel, special bolt/nut [#4] are needed. Correct?
              3.When you order a new metal pedal, are you getting the older metal type or is it the newer plastic type but made out of metal?
              Sorry for the seemingly dumb questions, I'm just confused.
              Thanks
              Originally posted by der affe
              What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
              Originally posted by navid41691
              And no, I use lotion so I don't have to worry about skin irritation.
              '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
              • JinormusJ
                • 6887
                1. No, but plastic does have its complications, so witching to a metal one would be Preffered to curb peace of mind
                2. Yes
                3. No, you should be receiving an early model metal pedal since that's what the part number is for.
                • WhyNot
                  • May 2012
                  • 363
                  2. Yes
                  thanks man
                  :D
