rear end whining
  • Bryan///
    • Nov 2011
    • 290
    rear end whining
    my rear diff is whining..has anyone brought theres to a shop for repair and can give me an estimate? or should I buy a new one/used one?
    '01 e46 330ci blk/blk (GF stole from me)
    '90 e30 325i Traded
    '95 e34 540i/manual swap (electric fire)
    '96 miata M-edition (not quite an e30 so i got below car)
    '93 Audi Urs-4 (like the e34 but still not an e30)
    :hitler:
  • Holland
    • Nov 2008
    • 7178
    Try a fluid change, it may very well work. If it's still whining then I would suspect the pinion bearings.
    Originally posted by DEV0 E30
    • kalib0y
      • Dec 2004
      • 3620
      if you change the fluid yourself then be sure to check the fluid for metal shavings. If you have chunks in there then its time to replace the diff
      95 7.1L 16V E36 M3
      Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
      LIKE my Facebook Page! CLICK HERE
      • Kershaw
        • 11822
        they all do that. really.
        it's just a matter of how much whining.
        AWD > RWD
        • QUKBMER
          • 8178
          Just give it some cheese with the whine.
          • Bryan///
            • Nov 2011
            • 290
            haha thanks everyone. Ill do a flush and go from there. The whining is bad around 3000 rpms and 30-45 miles per hour.. cant really tell on the highway but ill listen more closely next time
            '90 e30 325i Traded
            :hitler:
            • Jaxx_
              • Dec 2009
              • 1880
              is it the same on and off the throttle?
                If the whine changes with torque direction on the differential, the cause is probably wear or clearance issues with the ring and pinion gears. If the whine is constant worn bearing in the differential or wheels the more likely cause.
                The parts to rebuild an LSD (less the shims) run close to $500. And during the rebuild you will have to shim the pinion to get the correct clearance on the ring gear. Not a trivial process. A good used differential can usually be found for less than $300.
                Change the fluid in the differential (I use Redline 75w90 for an LSD or 75w90NS for an open differential) and check the wheel bearings.
                • fporro
                  • 1859
                  Do lsd's lock out after too much whine ?
                  mine whines on 3rd while goiing uphills, I shift up or down, relubricate and no whine for a 100 ft.
                  maybe a clucht problem ? seems that lsd is not functioning anymore.
