Pre-load
    Pre-load
    Well, everytime I do something I seem to have 3 more things to worry about. I went to replace the guibo and discovered a trashed center support bushing. The bearing itself seemed in, but all the rubber was gone so the drive shaft would just flop around.
    This is a project car, so I have never driven it more than 2 miles/hr.
    So I replaced the CSB following Bentley and many choice words when I could not loosen the spline clamp. When I removed the whole shaft, I needed TWO BIG pipe wrenches to turn it!
    when I put it back together, it discussed the preload, and I moved the csb housing forward and tighted to torque (16 ft lbs).
    but it really only felt like I was flexing the rubber surround inside the housing (big deal)
    Am I missing something? What is getting loaded?
    Thanks
    Ross
    The pre-load is on the rubber mount for the CSB. Since in almost all cases a failure of the CSB will be the result of binding u-joints in the driveshaft, don't be surprised if this CSB soon fails. The long term fix is to replace both the CSB and the driveshaft.
      The pre-load is on the rubber mount for the CSB. Since in almost all cases a failure of the CSB will be the result of binding j-joints in the driveshaft, don't be surprised if this CSB soon fails. The long term fix is to replace both the CSB and the driveshaft.
      What's a j-joint? I'm going to be replacing my fuel tank soon so I'm trying to get a handle on the jobs that are able to be done while everything is out. Never heard of a j-joint, Google isn't much help. Typo?
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
        Sorry, there was a typo in my post that I didn't catch (now fixed). I mean u-joints and there are two sets in the drive shaft.
          No worries, thought it might've been a typo. This is my first euro car, wanted to make sure I wasn't missing something. Thanks Jim.
          - Josh
          1990 325is
          Need a shift boot?
            I checked the U-joints when it was out. The front most one was very easy to pivot in all directions. The rear-most was good in one direction, and a bit stiff in the other. No clicking was heard. "So how much time do I have Doc?" Looking for an automatic driveshaft as I write this!
            I'm still a bit fuzzy on pre-loading. I put the new CSB on the shaft the same direction it was on by previous owner. Now I am worried it could be wrong. what should it be? I looked at RealOEM, as well as this post on another forum and am still unclear.
            The actual bearing sits in a hard rubber donut of sorts, which in turn is in a flexible round rubber membrane (reminiscent of a speaker surround), and then the metal housing. The hard rubber donut has a bit of a lip on one end so that the bearing fits inside it without going too far so which end does this lip go? Front of car or back?
            Thanks
