In neutral, when I rev my car and slowly press the clutch in, probably a centimeter or so of the way, I can feel a slight vibration in the pedal. When I'm rolling and I depress the clutch in, I can also feel this vibration in the pedal through every gear. I'm going to replace my throw out bearing, but can the idle vibration come from the pilot bearing? How do you know if you have a bad pilot bearing?
Also, I'm sure my clutch fork pivot pin is broken because when I pulled my trans to do the clutch it didn't seem like it was there anymore..
Thanks for the help anyone :)
