Can't drop Differential
  • mcruz121
    • 288
    I'm trying to drop my differential all the way down as seen here
    but it is stuck halfway down
    What should I do?
  • Holland
    • Nov 2008
    • 7212
    You need to unbolt the axles from the case and unbolt the case from the subframe.
    Not to mention you need to unplug that speed sensor!
    Originally posted by DEV0 E30
    • RUFFLZ
      • Apr 2011
      • 3122
      your diff is totally fucked now..time to get an lsd
      • RUFFLZ
        • Apr 2011
        • 3122
        jk this.
        • mcruz121
          • 288
          already unbolted the case from the subframe
          still cant lower it enough to take the springs out
          • e30Rooster
            • Jan 2010
            • 958
            lol go read the online bently. poor speed sensor =/
            • Holland
              • Nov 2008
              • 7212
              Don't forget to unbolt the driveshaft too...
              • mcruz121
                • 288
                Thats not my pic haha its from the instructions here: http://www.pelicanparts.com/bmw/tech...ear_Suspen.htm
                • slippery
                  • Nov 2011
                  • 379
                  You dont need to remove the differential to remove the springs.
                  J
                  • mcruz121
                    • 288
                    correct that's why I'm dropping it
                    J
                    • bmwstudent
                      • Sep 2011
                      • 1364
                      you don't need to drop it either. Do you have a bentley? You need one. The diff does not have to be dropped at all to remove the springs. Put the car on jackstands under the diff carrier. Put the jack under the trailing arm, remove the lower shock bolt. Slowly lower the jack until the spring comes out. I think thats it. Be careful lowering the swing arm, especially with the stock spring in place as it is rather long when uncompressed.
                      • Exodus_2pt0
                        • 5943
                        For spring install. (not in order.)
                        -Remove the bolt holding the shock to the control arm.
                        -Disconnect speed sensor
                        -Unbolt the sway bar end links from the control arms.
                        That should drop it enough to get the springs out.
                        No E30 Club
                        • Exodus_2pt0
                          • 5943
                          This is incorrect. If you don't remove the rear diff mounting bolt you will put a ton of strain on the axles and bearings. I realized it was an issue when the drivers axle popped out of the diff. lucky I caught it instead of driving like that, otherwise I would be shopping for another lsd and axle.
                          No E30 Club
                          • mcruz121
                            • 288
                            Thanks for the help!!! Worked to perfection
                              • 37833
                              I've NEVER dropped a diff to change springs. I also recommend unbolting the sway bar links to get the trailing arms to drop a bit more.
                              Grover Beach, California
                              BimmerHeads.com
