shifter support carrier removal?
  • TheBlik
    • Nov 2011
    • 150
    Alright, a friend and i are doing a 5 speed swap. We were at pick and pull yesterday trying to get all the linkages and what not. So i got the shift linkage out and then i unbolted the carrier and tried to wrestle out the part that connects to the trans. i know there is a clip and the retaining pin, but how in the world do you take it out.
    sigpicDiRTYE30-RALLYE30
  • Sagaris
    • Sep 2009
    • 2243
    Once you pry the clip up (with a flathead screwdriver or other similar object), rotate it as far as you can away from its "locked" position so that it doesnt get hung up on the trans. case After that, the clip + the rod it is attached to should come straight out horizontally on the drivers side.
    I hope that makes sense
    • FredK
      • 14764
      • e30shmobberr
        • 1934
        Originally posted by TheBlik
        But how in the world do you take it out.
        By removing it ha. Like what they said above. It can be a walk in the park or a bitch
        Patrick - IG:niicknac
        RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
        • TheBlik
          • Nov 2011
          • 150
          AHHHHHHH! thanks guys. silly lil bugger gave me the hardest time.
