what size nut on early model drive shaft?
  • mr.vang
    • 4371
    what size nut is it on the end of the drive shaft where it connect to the differential? i'm trying to get a S3.73 out of a 87 325is. so far i try 17mm and its seem too loose and 16mm is too small. usually 17mm fit like a charm.
  • accident
    • 7303
    Is the nut rounded?
    Moral of this story?
      • 37834
      17mm is the correct size.
      Grover Beach, California
      BimmerHeads.com
      • mr.vang
        • 4371
        Originally posted by accident
        Is the nut rounded?
        nope, it look exactly like the original 17mm nut.
        • Eddie Haskell
          • 102
          I noticed this on my OEM DS/Diff.
          I used a 21/32 I had from some lathe tooling.
          A 1 1/4" open end will work on a fan nut, sometimes it needs a little grinding for thinness.
          A Mapp torch or O2/Acy heat is your friend on those along with Kroil if they are virgins.
          • stamar
            • Apr 2011
            • 1362
            17 mm on all e30s except m3s and some etas.
