so last night at midnight i was letting my Fiancee drive around a vons parking lot in my car to learn how to drive a stick nothing to out of the ordinary then all of a sudden the shifter went loose and was stuck in 2nd gear. so look under the car and the shifter arm joint that connects to the gear selector had sheared off (i have a shitty steel plate shifter)...so lucky one of my friends was with us and we got home. the next day we go to picknpull and the only e30s there are autos...course right...so i pulled the linkage off a 5series hoping it would work drive 40miles are so back to the parking lot at around 1200 begin tearing everything apart was going okay until i noticed the previous owner had totally fucked with everything and instead of using the normal easy clips they used the small circlip ones
so that wasted a good 1 1/2 hours of precious time after another 2hours or so i finnaly got everything off (the rear mount bolt sucks...) and obviously the 5 series mount would fit perfectly if it was shorter(i have the tranny wit hboth mounting spots) so my friends ran over to a fab shop just as it was closing and asked them to weld the arm back together so after another 2hours of suffering in 95 degree heat finnaly got it all back together at 630..now when i shift into 4th from 5th the shifter hits the driveline and reverse is right in the middle of the where 3rd should be:hitler:
