Driveshaft Center Support Bearings and 1-piece Driveshafts
  • S13_E30
    • 309
    Does anyone know of solid ones? the oem rubber ones don't seem to last much. I was also considering going with a 1 piece driveshaft does anyone know where one can be purchased for a reasonable price?
    • 34839
    they seem to work fine for most people - what kind of powerplant do you have? are you certain they were installed correctly? BMW parts or aftermarket?
      The OE Center Support Bearing is typically good for about 20 year and something in excess of 150k. Seems to me to be pretty decent life.
      If you are experiencing early failure of the CSB the cause is probably binding u-joints in the drive shaft. Replace the drive shaft and CSB and you won't have to worry about for a long time.
      • S13_E30
        • 309
        I have the tiny 1.8 so you know it's not a power issue that is causing it. Yeah they were installed correctly or so I assume the shop the put them in did, and this was around 2 years ago, while taking my subframe out yesterday I took a peek just to see what was going on there and noticed it was out again -_- first time it was replace about about 5 years ago. They were the oem CSB.
        • S13_E30
          • 309
          Originally posted by jlevie
          The OE Center Support Bearing is typically good for about 20 year and something in excess of 150k. Seems to me to be pretty life.
          That is probably the problem and like the other guy stated... it might have not been installed correctly..
            • 37832
            Are you sure it was an OEM or Febi CSB? The China ones don't hold up for shit.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • S13_E30
              • 309
              I went straight to the BMW dealership and got one.
              • e30leigh
                • Mar 2012
                • 481
                ive seen them installed backwards. and binding UJ's can play a big part on driveline issues.
