"618" pressure plate
  • tinkerputzer
    • Jun 2008
    • 508
    Anybody know where the cheapest place to buy it? This is what i've found so far.
    Also read that an e30 m3 clutch kit works. Anybody have any feed back on that? Does that use a 618pp?
  • e30leigh
    • Mar 2012
    • 481
    why not buy an item from spec clutch? do you need heavy clamp? otherwise get a genuine or saches item
    • tinkerputzer
      • Jun 2008
      • 508
      I'd like to have a bit more clamping force than stock (going on an m20 stoker motor). The 618 is made by sachs performance and seems to be popular option.
      • Wanganstyle
        • 2828
        buy a complete 240mm m30 or s38 clutch setup with flywheel you like the weight of.
        drops in and its 240mm vs 228.
        • tinkerputzer
          • Jun 2008
          • 508
          That works with an m20 and g260? Does it use a different fly wheel?
            • 34835
            the 618pp IS a sachs item.
            it's for any E30 single mass flywheel, 228mm clutch. M3, M20, etc. holds 300nm with a stock disk.
            • tinkerputzer
              • Jun 2008
              • 508
              Found a 618 PP, but i can't find any definite answers on what throw out bearing to use with it. According to bav auto 21 51 1 204 525 is the throw out bearing to use. The pelican parts website says it fits these vehicles.
