Which tranny does my 91 318is have?
  • madsedan
    • 222
    I've seen people mention a G240 and some spec sheets I've found online mention the 90-91 318is came with a g260 which is a more stout tranny. The car will be getting an S50, its at the shop for the swap now.
    '91 318is, S50 swap, Bilsteing/H&R race, Recaro SRD, etc.
  • drumad
    • Aug 2009
    • 1700
    I'm curious, do you have links to these spec sheets?
    I'm pretty sure you have a g240.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • jeffw
      • 1087
      g240
      • MrSlacker
        • 2494
        G260 is for M20
        My Seller/Buyer Feedback
        Performance Aftermarket Parts & Accessories
          • 37834
          100% a Getrag 240 transmission. It will work with the S50 but I don't recommend it. The 240 trans is a bit weak.
          Grover Beach, California
          BimmerHeads.com
          • madsedan
            • 222
            Find information, resources and relevant links for e30world.com. This domain may be for sale.
            • madsedan
              • 222
              OK, so if I have a 240 I should plan on having to replace the tranny down the road, and dont do clutch drops lol.
              They are installing a medium case 3.73 lsd with the build, should I start shopping for a g260 to drop in, and would it be a direct swap with the 240 paired with the S50?
              • drumad
                • Aug 2009
                • 1700
                260 bellhousing tilts the shifter by approx 15deg or so, forgot to which side though, this will require you to have a different tranny mount and a bent shifter/selector. Several members here make the mounts. Also, UUC makes a dssr rotated selector.
                260 also doesnt mount up to the block perfectly, not every bolt is used, not a problem however. The 240 uses every bolt.
                You can also go with a zf.
                edit: That spec sheet you linked is definitely wrong.
                2008 335i - n54b30
                1991 318i - m52b28
                • madsedan
                  • 222
                  Any reason not to use a ZF? Obviously it bolts right up to the motor but any issues with tranny mount or drive shaft going with a ZF?
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    ZF trans will require a large guibo driveshaft (do a search, lots work), and being as it is a 1:1 fifth gear (no overdrive) I would reccomend not more than a 3.25 rear diff ratio. other than that, no issues with a ZF swap. They bolt right up, handle more power than a G260, and no parts needed other than factory BMW parts.
                    I saved 15% on my Bimmer parts by switching to ...
