play in the shifter???
  • 90pioneer
    • Jul 2011
    • 78
    Just bought a 91 318I, 5 speed. Clutch is pretty new and it shifts fine. It just seems like the shifter is loose or has a lot of play in it. In my old 91 318is the shifter was nice and tight, did not feel slopy at all like this one does.
    What should I look for?
  • Vivek
    attention whore/retard/bitch
    • 6167
    Shifter bushings.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • Cletonius
      • 2809
      Originally posted by Vivek
      Shifter bushings.
      This. Or just learn where the gears are and hope for the best. GL, try not to money shift
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • 90pioneer
        • Jul 2011
        • 78
        Shifter bushings.
        How do I replace them? Where should I buy them from, and how much are they going to cost?
        • Zzyzx85
          • May 2012
          • 130
          it's pretty well documented and commonly done. search in the drivetrain section.
          Gotta remove the driveshaft to get access to the linkage.
          - '89 325i 4-door, Alpinweiss, 5-spd swap (and lots of maintenance) in progress
          - '03 M3, Imolarot, 6 speed
          • Vivek
            • 6167
            Here you go.
            http://www.pelicanparts.com/bmw/tech...t_Bushings.htm
            • e30BMart
              • Feb 2011
              • 658
              if I was close i'dd come help you with it.. the first time around can be frustrating.. but once you've done it you realize its quite easy. I wouldnt waste my time changing all the bushings though... I changed only the white bushing where you shifter ball sits (the point of pivot) and everything became 100x tighter. Lift your car, remove the clip holding the shifter, seperate what it held, go on top remove the shifter knob and boot (leather), remove the rubber sound barrier and with two small flat head screwdrivers insert them in opposite sides of the white bushing (in the cracks) and intertwine the screwdrivers to be able to twist the bushing. Pull it up and out replace and inverse the process to put back in. Simple. I hope you understand my steps :p
              Good luck
              Martin
              Sent from my Galaxy Nexus using Tapatalk 2
              • ZekeTheSneak
                • 1562
                Your posting too much, Search. go to google.com type in sloppy shifter site:r3vlimited.com and bam results. Now quit posting nonsense!
