Short Shift Hell!!!
  • 318i sTiLL FLy
    • Nov 2005
    • 82
    Short Shift Hell!!!
    how the hell i get these peices off the old lever on the right and on to the new short shifter on the left.....
  • Il Duce
    Non-Mod M42 Modder
    • 5040
    you have an early e30, it doesnt have the usual stuff we always talk about. i used to have an 85 325e with a SSK, i cut the old lever in half, something i wouldnt recomend doing. but if it comes down to it, do what you have got to do...
    *edit*
    noob.
    • BS87
      • 1606
      From what i can see the distance above/below the ball are the same thus it wont be any "shorter" plus why would you want to re-used 14 year old warn out grimy plastic? Dont be cheap, if your going to do it, do it right and buy new plastics/bushings for like, 15$.
      • 318i sTiLL FLy
        • Nov 2005
        • 82
        This is what i need removed.
        • 318i sTiLL FLy
          • Nov 2005
          • 82
          well it's 3 inches shorter then my other one so short enuff for me. HOW DO I GET WHERE THE ARROWS ARE POINTED OFF!?!?!?!??!?
          • King Luis
            • Sep 2004
            • 737
            BUY NEW PIECES.
            Don't be a cheapo.
            • Jand3rson
              • 37587
              The only difference I see between those 2 levers is the height of the stalk, above the flared-out portion above the ball. What you have isn't a short shift lever, it's a shorter lever. It will do next to nothing in the way of make your shifts shorter or quicker. Whoever sold you that lever and told you it was a short shift screwed you.
              That being said, buy a real short shift kit, and lose the attitude. Quickly.
              - Josh
              • golde30
                • 11464
                cut the old lever and take them off, then have fun tryn to get the on the new one...
                IG: @Baye30
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  Dude, all of those pieces are less than $2.
                  PS - you can't get them off without cutting the lever. Also, if the rib on the upper part of the lever is larger (or as large) in diameter as the fulcrum, you're SOL.
                  Originally posted by Gruelius
                  • King Luis
                    • Sep 2004
                    • 737
                    money isn't an issue with those parts. assuming these are the right ones....
                    LOCK RING.........................23411466112........$0 .66
                    SPACER SLEEVE..................23411200844........$1.21
                    COMPRESSION SPRING.........23411200845........$1.12
                    BALL CUP UPPER.................23411466110........$2.51
                    now...they aren't that expensive are they?
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      This might sound kinda ghetto.. but I just took some sharpened wire snips and snipped the metal spring retainer ring and the plastic ring a clean as I could. Pulled them apart just enough to get them off the old shifter onto the new one. The spring just twists off like a key chain ring.
                      Seriously though.. if $6 is too much money for you to spend on some misc. maintenance parts you're gonna be in a world of shit when it comes time to change your oil.
                      • Rob
                        • 8166
                        That's not a short shifter, no matter what you think.
                        Listen to Ken's advice.
                        BEERTECH
