What Tanny Oul
  • Rajun Cajun
    • 17
    What Tanny Oul
    Hey guys, I have a '91 325I with a manual tranny. Drained the oil and it smells like gear oil because of he sulfur. Boof says look for a colored tag to determine oil type. Where would this be?
    TIA
    Andy J
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    I love the way the South comes through the keyboard.
    • Rajun Cajun
      • 17
      Yes
      Sorry, need my glasses !
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I'm just razzing you!
        That with a green label and a 17mm hex drain plug uses MT-90, a red label and 17mm plug uses D4 ATF, and that with no label and a 15mm drain plug uses MTL.
        Passenger side of the transmission!
        • ak-
          • 12422
          Who's boof and where can I get in contact with him.
          1991 325iS turbo
            • 37833
            Gear oil is correct. I run 75w90 or 80w90.
            Grover Beach, California
            BimmerHeads.com
            • Rajun Cajun
              • 17
              I appreciate the reply and help. I have Vavoline 80W-90 and Vavoline 80W-90 Synthetic Blend. Synthetic blend better for this application?
                • 37833
                I personally just use the regular old Valvoline or Castrol but it's ultimately up to you.
                BimmerHeads.com
                • Vivek
                  attention whore/retard/bitch
                  • 6167
                  I'd put the synthetic blend in just because you don't change tranny oil that often. I use conventional in my engine.
                  1992 Mauritiusblau Vert
                  2011 Alpinweiss 335is coupe
                  2002 540i/6 Black/Black
                  2003 GSX-R 750 (RIP)
                  • TobyB
                    • 5280
                    ...and I make sure it says GL4 not GL5... just out of paranoia...
                    t
                    • WhyNot
                      • May 2012
                      • 363
                      i think that there if the drain plug is a 17 mm male [like a nut] then its auto trans fluid [before 91] and if its 17 mm female [you need an allen wrench] then its gear oil, i think.
                      as stated dont use gl5 it eats up the yellow metals like synchros.
                      the owners manual for '91 says non-hypoid lube but i couldnt find anything that said it was non-hypoid.
                      i used synthetic mtl.
                      Originally posted by der affe
                      What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
                      Originally posted by navid41691
                      And no, I use lotion so I don't have to worry about skin irritation.
                      '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
