My selector rod broke, and i ordered one from the stealer, told them i had an 87. I dont have a flex disc on the driveshaft. The one I took off has no indent for the flex disc, the one I got from the dealer does. So aparently there are two rods, and one is longer than the other? Is this correct?
When i installed the lever my shifter was much more forward than before. Basically neutral is where first used to be. I am correct in bending the rod and shifter to help correct.
