Can't get into 2nd gear. Help!
  • series88
    • Nov 2011
    • 1231
    I have a 91 318 and recently, my car has been having trouble getting into 2nd gear and sometimes on 3rd. I checked the brake fluid reservoir to see if its low and it wasn't bad. I thought there might be some air in the system since my brakes were kinda funky so I bled the brakes and clutch as well. Gets into third now but 2nd is still an issue. It pops out but when I hold it in, it will grind and eventually get into gear. I think I have a g240 correct? Has anybody had this issue? Could the synchro be going out? is the "y" selector bad?
  • carguy101
    • Jul 2009
    • 495
    The synchro may be going out, when was your clutch, slave, etc. last replaced? How are your shifter bushings?
    I know that sometimes I have to change where I would think 2nd gear would be (granted this is under heavy braking and turning in an autox for a 3-2 shift) I would have to pull it back as if I was going into 4th. Try double clutching and see if that helps, as it is a technique for non-synchro cars. Report back, I am intereted.
    Jeff
    • mr.vang
      • 4371
      mine is a pain to get in 2nd after couple runs down the 1/4 mile.
      • series88
        • Nov 2011
        • 1231
        Jeff
        Not exactly sure when the clutch was replaced but p.o said it was just done prior to selling the car. I personally had checked it out and it's pretty new. Slave is new. I replaced it about 1.5 months ago. Old one went out while swapping engine. double clutching sometimes work but very seldom though. Most of the time it doesn't help.
        Mine is a pain no matter what. :(
        Also, btw, my throw out bearing is making noise and needs replacing. Would this affect shifting? What baffles me is that when I added brake fluid, third seemed to work 20x better but did not change 2nd at all. I got it in 2nd perfect once and thats about it
        • series88
          • Nov 2011
          • 1231
          Could it be just the shifter bushing?
          • u3b3rg33k
            • Jan 2010
            • 2452
            Jeff, your problem sounds like the engine/trans are moving around under braking / turning.
            Ich gehöre nicht zur Baader-Meinhof Gruppe
            Originally posted by Top Gear
            Just imagine waking up and remembering you're Mexican.
            Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
            • carguy101
              • Jul 2009
              • 495
              It very well could be, I was having the same problem before I replaced the trans mounts (they were both in two pieces). Replaced them, a little better but still meh. I guess it's time to replace them and my shifter bushings too.
              • series88
                • Nov 2011
                • 1231
                Anyone who might have an idea about my problem?
                • Vivek
                  attention whore/retard/bitch
                  • 6167
                  To be honest, replacing the transmission may be the simplest and most effective thing to do. There's someone on here selling a ~95k g240 in sunnyvale i believe. I think CJ is also selling a higher mileage one that shifted fine for pretty cheap.
                  But do at least check your bushings first.
                  1992 Mauritiusblau Vert
                  2011 Alpinweiss 335is coupe
                  2002 540i/6 Black/Black
                  2003 GSX-R 750 (RIP)
                  • series88
                    • Nov 2011
                    • 1231
                    I might be doing that. I just didn't know if it's really necessary to do the whole transmission or just the linkage. Im talking to someone about getting a g240.
                    • u3b3rg33k
                      • Jan 2010
                      • 2452
                      Mounts are pretty cheap, and if yours are original, it's probably time anyways. do all four (engine and trans).
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        Normally you replace the TOB when you do a clutch so unless you rest your foot on the clutch pedal, a recent clutch swap shouldn't have TOB issues.
                        Trouble getting into to gear is either a synchro or the clutch not disengaging which you suspect, but popping OUT of gear is typically worn internals (bearings & bushings) or conceivably broken teeth.
                        Alice the Time Capsule
                        • series88
                          • Nov 2011
                          • 1231
                          Well the TOB whines so I figured it wasn't replaced by p.o. And a big mistake my me was forgetting to change it while doing the engine swap. I was more worried that the replacement engine I got was also shot. We were just supposed to test it out then drop it again.
                          But yeah, it's not so much that it pops out. It's more like tough to get in and would get 3/4 it's way in then grinds and pushes itself out. but if I hold it in, it will eventually get into gear and drive normally on 2nd.
                          • ieatpeople
                            • Mar 2008
                            • 883
                            sounds like you need a trans, but you should replace all the motor /trans mounts and shifter bushing as well.
                            Originally posted by BillBrasky
                            That's like Vlad challenging Chip Foose to a car painting contest.
                            Originally posted by acolella76
                            i'm pretty sure 'Phillis' is short for syphilis
                            2007 CVPI, stock and slow
                            1994 tercel, 5efhe swap, i/h/e
                            1984 t-type, 5.3/th350 swap in progress
                            My newest addition:
                            Rebecca Arlene, born 4/19/2013
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              The synchros are the 1st thing to make contact when you shift (hence the name) so once you get past them any problem getting in to or staying in gear would indicate worn out internals. If it literally feels like its pushing itself out of gear, time to start looking for a replacement. Obviously, more to do once you are in there :-)
