Sorry if this has been asked before, I did quite a bit of searching (here and Google).
Often I will hear a rattle when I press down on the clutch. It isn't a continuous sound, it makes a short rattling right as the clutch is pressed down. Usually it happens when I am giving it some good gas and go to shift quickly.
Also, when the car is off, if I quickly release the clutch while it's down, I hear a sort of "snap" sound... not sure if this is normal or unrelated to the issue above.
Any ideas?
random thought: does depress mean press DOWN on clutch or release? Depress sounds like the opposite of press...
Any ideas?
