So my trusty dirty30 took a time out today. I've put over 200miles on her over the past two days and had no problems whatsoever. Today mid-day I started to hear this "Tin can full of rocks" rattle coming from the rear end. Odd behavior since I only get this noise when I am off the throttle and the car is rolling in gear. Clutch in/Accelerating/Rolling in Neutral and Shifting, the sound does not happen.
So I jacked the rear end up, hoped in and started it up, tranny shifts fine and no noise getting up to 3rd gear. So this only happens when the car is rolling in gear and off the throttle.
At first I thought it was a bad wheel bearing, since I've been hearing clicking in the rear, however that still doesn't make sense since I don't get the sound all the time. For kits n giggles I took the wheels/calipers off and I don't have any play in the hub or hear anything out of the usual.
What do you think I have going on here? Diff? Busted CV? Maybe the catalytic converter broke and its rattling from the back pressure? I'm just curious for what I should look into, the car is 2h away at a friends house and want to get my thoughts straight before I take the weekend off and rip the thing apart. Any advice is appreciated! :)
Take a listen for yourself
