Sweet bump! Didn't see this the first go around.
Deleted
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950 -
DeletedLast edited by Wanganstyle; 09-26-2020, 05:43 PM.OBD1 M54/M52TU swap as a M50b25
hi
wellcome to this forum sites here you can find lots of thing i suggest you for problem you have to contact any other expert know i have no knowledge about your question sorry for that.......
top ten classified websitesComment
DeletedLast edited by Wanganstyle; 09-26-2020, 05:44 PM.OBD1 M54/M52TU swap as a M50b25
E30/S52 + e46 M3 6-speed. I just buy the two parts you show in the first post and I'm golden?S52-Powered 1987
sigpicComment
You need to read.
Sent from my SAMSUNG-SGH-I337 using TapatalkOBD1 M54/M52TU swap as a M50b25
Well, you see, I did read, but nowhere does anybody use the letter-number combo "M3" in a post on this thread. That's why I asked the question. The M3 trans is different, and I'm unclear if the rear mounts are different. Also, I can't tell from your pics whether you have to use a modified e30 rear cross-member, something different entirely, the stock one with wings, or just stock.S52-Powered 1987
sigpicComment
Title of thread:Well, you see, I did read, but nowhere does anybody use the letter-number combo "M3" in a post on this thread. That's why I asked the question. The M3 trans is different, and I'm unclear if the rear mounts are different. Also, I can't tell from your pics whether you have to use a modified e30 rear cross-member, something different entirely, the stock one with wings, or just stock.
Bmw Oem part avail to mount zf6 speed transmission (2005+) into e30
Here are 2 questions that only you can answer:
Is your E46 M3 transmission a ZF?
Did you even look at the item you purchased? Usually ........USUALLY the BRAND of make is on the actual gearbox
What you mean I have to read the title too? D'oh!Title of thread:
No, it'll be a getrag. Guess I'll have to buy a custom.S52-Powered 1987
sigpicComment
DeletedLast edited by Wanganstyle; 09-26-2020, 05:45 PM.OBD1 M54/M52TU swap as a M50b25
