Deleted
  • Northern
    I like cupcakes & sh!tboxes
    • 5270
    #46
    Question regarding this item from zionsville.
    Is this for 2008.5+ compatibility with E36 style flywheels, or for all newer ZF6 wanting to run an e36 flywheel?
    There is a local 2007 328i 6 speed for sale, I'm looking to run with my M52B28/aftermarket single mass 240mm flywheel.
    Originally posted by priapism
    Originally posted by shameson
    • digger
      • Nov 2005
      • 6173
      #47
      anyone have a list of ratios for the ZF 6 speed that will fit the m20 in place of the G260?
      im assuming there is more than 1 set of ratios?
      • Wanganstyle
        • 2828
        #48
        Deleted
        • Northern
          • 5270
          #49
          Thanks H, I just bought this ZF320 flywheel/clutch setup and new OEM bearings, slave, etc. Too much money to start again right now, maybe in the future.
          I found one mention of that zionsville piece vibrating loose... lots of potential to damage things there.
          • Wanganstyle
            • 2828
            #50
            Deleted
            • Nutzy
              • Sep 2011
              • 102
              #51
              The figures in this chart are with a 3.15 diff. It is possible the GS637DZ has different ratios to the GS637BZ. I am finding 1st gear so low on this box I am just using 2nd gear from a dig with the M50B28 turbo vanos motor. I'm running a 3.25 LSD diff at the moment.
              89 M50B28 turbo
              LINKY
              • bmwe30s52SC
                • Jun 2014
                • 6
                #52
                I have the zf gs6-37 transmission from an E46 330ci I believe. installing it into my E30 that has S52 w/ g260
                Just ordered my 22 spline clutch disc w/ e36 m3 pressure plate from UUC,
                I got the pilot bearing adapter from TC Kline (i think. zionsville has no interest in selling it anymore individually)
                Ordered the double sheer shifter carrier, and factory selector rod.
                now im going to order the part mentioned in the OP, looks great thanks for sharing! too bad its not $20 anymore haha.
                Now I'm wondering, should I just fabricate something together for the bottom piece / cross member or is there an OEM piece I can buy that gets pretty close?
                Do i use the E90 automatic one or the E46 6 speed one.
                I currently have a white325is brace.
                • Curt Hayes
                  • 476
                  #53
                  I can't find that adaptor on the tc Kline website. Do you have a part number?
                  S52-Powered 1987
                  • Nutzy
                    • Sep 2011
                    • 102
                    #54
                    Use a 330i FW. What FW do you have (if any) right now?
                    89 M50B28 turbo
                    LINKY
                    • jayuuey
                      • 414
                      #55
                      Just bought a used g260 and sold my 3.25 lsd. Fail x2. Great info though. Thanks!
                      • Curt Hayes
                        • 476
                        #56
                        I have the e36 M3 one that matches my e36 M3 trans. I have an e46 M3 6-speed that I'm going to install this fall and I just want to get the pieces together. Trying to figure out if I need a new flywheel and that adaptor or just a new disk.
                        S52-Powered 1987
                        • jph
                          • Feb 2015
                          • 463
                          #57
                          Bump for any more new info out there
                          • Wanganstyle
                            • 2828
                            #58
                            Deleted
                            • Curt Hayes
                              • 476
                              #59
                              Originally posted by Wanganstyle
                              A. S52 engine S52 flywheel+ 6mt Getrag 420 friction disc + s54 pressure plate + 6mt g420 getrag transmission is proven compatible.
                              Did you mean S52 or S54 pressure plate?
                              I'd heard that the G420 has a short input shaft and the pilot bearing is in the flywheel? That's why I'm asking. Just trying to plan ahead so I'm not air-freighting heavy parts around trying to get my car back on the road in minimum time.
                              S52-Powered 1987
                              • Wanganstyle
                                • 2828
                                #60
                                Look at photos on the interwebs.
                                Dont ask for spoons to feed on
