Deleted
  • Ray Smoodiver
    • Jun 2004
    • 8809
    #31
    Sweet bump! Didn't see this the first go around.
    • 89AlpineM3
      • 548
      #32
      Pm sent I have a couple questions on what flywheel and clutch to use on my S54 Zf 6 speed swap
      • Wanganstyle
        • 2828
        #33
        Deleted
        • 89AlpineM3
          • 548
          #34
          Thank you for the info
          • Bay_bmw
            • 11
            #35
            What options do i have for clutch and flywheel if i wanted to install the gs5-53bz out of the 335i onto a s52? Will the flywheel off a e36 work? Are there any issues with the install due to the input shaft being inverted?
            • JinormusJ
              • 6887
              #36
              Woah
              Seriously
              How have I not seen this until now?
              Pictures of the full setup installed?
              • redifflion
                • Apr 2014
                • 1
                #37
                hi
                wellcome to this forum sites here you can find lots of thing i suggest you for problem you have to contact any other expert know i have no knowledge about your question sorry for that.......
                top ten classified websites
                • Wanganstyle
                  • 2828
                  #38
                  Deleted
                  • Curt Hayes
                    • 476
                    #39
                    E30/S52 + e46 M3 6-speed. I just buy the two parts you show in the first post and I'm golden?
                    S52-Powered 1987
                    • Wanganstyle
                      • 2828
                      #40
                      You need to read.
                      Sent from my SAMSUNG-SGH-I337 using Tapatalk
                      • mkcman17
                        • Jul 2010
                        • 8240
                        #41
                        Oh cock and balls. I just finished this swap with fabricated braces. Could have saved myself quite a bit of headache!
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                        • Curt Hayes
                          • 476
                          #42
                          Originally posted by Wanganstyle
                          You need to read.
                          Well, you see, I did read, but nowhere does anybody use the letter-number combo "M3" in a post on this thread. That's why I asked the question. The M3 trans is different, and I'm unclear if the rear mounts are different. Also, I can't tell from your pics whether you have to use a modified e30 rear cross-member, something different entirely, the stock one with wings, or just stock.
                          S52-Powered 1987
                          • Wanganstyle
                            • 2828
                            #43
                            Title of thread:
                            Bmw Oem part avail to mount zf6 speed transmission (2005+) into e30
                            Here are 2 questions that only you can answer:
                            Is your E46 M3 transmission a ZF?
                            Did you even look at the item you purchased? Usually ........USUALLY the BRAND of make is on the actual gearbox
                            • Curt Hayes
                              • 476
                              #44
                              Title of thread:
                              What you mean I have to read the title too? D'oh!
                              No, it'll be a getrag. Guess I'll have to buy a custom.
                              S52-Powered 1987
                              • Wanganstyle
                                • 2828
                                #45
                                Deleted
