Deleted
Deleted
This is interesting. I see you say that a diesel version of the 6-speed is needed for the m20 tilt, could you just use an AKG style shifter (for lack of better term) and a custom dssr like many of the m30 swap guys make?
I just ask because a 6 speed could be nice, and fresher than old g260's.
But what if I have a custom ASP flywheel for e36 (s52) with a quartermaster triple disc clutch. How would that fly? hahahasigpic
Instagram @rebellionforgeComment
DeletedLast edited by Wanganstyle; 09-26-2020, 05:49 PM.OBD1 M54/M52TU swap as a M50b25
Everything.
Sent from my iPhone using TapatalkOBD1 M54/M52TU swap as a M50b25
I do believe he is talking about the same two pieces.Comment
The stock oem e9x transmission support brace does not fit the e30. The first piece he mentioned in the first post can be used in conjunction with the custom g260/e30 brace made by a member here.
I'll be stuffing the gs6-53bz into my swap they can take massive amounts of abuse; gentlemen on the diesel forums are using the 53bz to transfer 1200wtq cummins/powerstroke etcLast edited by the imitator; 03-20-2016, 01:59 AM.Comment
335i, 335d, M3, M5, M6, and some other models however; The bell housing on the M series vehicles have a much different bolt pattern, not even close. The 335i GS6-53bz is the transmission to use in this case, you'd be happy to hear that a great percentage of the bolt pattern matches up in 24v cases.Comment
Hi Guys.
Does this thread relate to 330CI Manual ZF 6 Speed gearbox?
Also what to do about driveshaft, has anybody found anything off the shelf that can work? Or is it always going to have to be 330CI front section and E30 rear section with extension or shortening done?
Thanks.Comment
So I'm finally taking the dive. I've sourced a Zhp ZF trans with flywheel, shift linkage, and clutch. It wasn't covered in this thread and maybe it's an unspoken truth. I'm assuming the driveshaft does not need to be modified, and the only engineering but would be the shift linkage for how the trans is rotated? I'll be sourcing the trans brace from
Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
Or here
Only E46 M3 Getrag 420 transmission is supported as of 9/2023. Kit provides a turnkey mounting solution for various BMW bolt-up transmissions for E30 swaps available for a variety of transmissions including: E46 M3 6-speed (Getrag 420G), E46 330i ZHP 6-speed(ZF GS6-37),E46 330i ZHP 6-speed(ZF GS6-37), E90/E60 6-speed (ZF 6HP26); Includes ALL necessary hardware to make mounting transmission […]
Feedback would be awesome as I've read this whole thread and didn't pick up on itsigpicComment
Or here
Feedback would be awesome as I've read this whole thread and didn't pick up on itComment
