drive shaft vibrates like a bitch
  • Killacortes
    • 1937
    This is on a 86 325es automatic and has no Guido. I know a five speed swap would fix this problem but it's not going to be my car anymore. I replaced the center support bearing and tranission mounts but only helped it a little.
    Is it safe I say my U joints are bad on my driveshaft and needs to be replaced? Or does this seem like a problem with the output shaft of the transmission.
    r3v does not fuck around. First you get banned, then they shoot you
    If you feel the vibration as if it was from under the car and if the rubber mount of the previous CSB had failed, then it is almost certain that the vibration is from bad u-joints in the drive shaft.
    • JCarp90
      • Feb 2011
      • 1759
      From the factory it has no guibo? I didn't know they did that.
      I doubt it's the transmission. I'd drop the DS and put on a new CSB before I do anything else. They're like $25 so fuck it if you're wrong. Probably could have been replaced anyway.
      Also I've got a spare 4HP22 laying around from when I did my 5-speed swap. Take it off my hands lol.
        He has already replaced the CSB. But since in almost all cases a failure of the CSB is caused by bad u-joints in the drive shaft, I'm going with a bad drive shaft.
        • Killacortes
          • 1937
          Thanks bro! Is it normal for the driveshaft to have no guibo? This is my first auto e30
          • JCarp90
            • Feb 2011
            • 1759
            Mine had a quibo. If you don't have one, you probably have the wrong DS or your trans is F'd because someone decided to not replace the guibo.
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              All E30's, manual or autotragic, had guibo's. Without them, there'd be premature wear on the rest of the drivetrain not to mention the transmission.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • Killacortes
                • 1937
                damn thats fucked! when i took everything apart there was no guibo! guess OP must have taken it out
                • Killacortes
                  • 1937
                  well after readin a couple threads some e30s didnt come with guibos at all. i have a 4 bolt output flange and no guibo.
                  now my question is, can i swap the output flange to a 3 bolt one and use a driveshaft from an auto car?
                  • stamar
                    • Apr 2011
                    • 1362
                    k wait you hav 4 bolt out put but on the transmission theres 3 bolts flange
                    whats in the middle?
                    take a picture of that please
                    so thats 7 bolts going into something. Even if its not a guibo its taking the place of a guibo
                    • Killacortes
                      • 1937
                      im saying i dont have a 3 bolt output flange. i have a 4 bolt one so there is nothing in the middle where the guibo would usually go. its just tranny to driveshaft held by 4 bolts. ill take a pic when it gets taken apart again
                      • Skunkworks
                        • Sep 2012
                        • 436
                        I have a 4 bolt auto DS if you need it, I would be willing to sell it. PM me
                        • Killacortes
                          • 1937
                          Thanks bro but picked up a 3 bolt DS and just gonna swap out the output flanges
                          • bmwman91
                            • Oct 2004
                            • 3134
                            Also make sure that the two halves of the driveshaft are properly aligned. There is ONE orientation that they go together in where they will not create a speed-dependent vibration because they were co-balanced in that orientation. There are usually two white alignment marks in the yokes that are supposed to line up. Clean things up around there & see.
                            Transaction Feedback: LINK
                            • Killacortes
                              • 1937
                              Yea for sure man. I got worried before when I forgot to mark the splines until I found the two white dots
