So here's my situation:
I pulled my M20B25 drivetrain on Sat due to a spun rod bearing (have a lower mileage M20B25 almost ready to drop in) and I discovered the IE poly trans mounts I was running were sheared in half.....just the weight of the equipment was holding it in place
My present motor mounts are IE poly as well (they are just fine).
My friend helping with the task suggest I call AKG to inquire about their poly (75D rated) trans mounts which have a thru-bolt design (which I did, very helpful & knowledgeable folks). My question is: how do the poly IE motor mounts compare to the AKG items in terms of hardness? IE doesn't rate their poly items for stiffness/density. Would I be ok with this mixed set of poly mounts or should I just go with one brand (and known desity) for engine & trans?
Jon
My present motor mounts are IE poly as well (they are just fine).My friend helping with the task suggest I call AKG to inquire about their poly (75D rated) trans mounts which have a thru-bolt design (which I did, very helpful & knowledgeable folks). My question is: how do the poly IE motor mounts compare to the AKG items in terms of hardness? IE doesn't rate their poly items for stiffness/density. Would I be ok with this mixed set of poly mounts or should I just go with one brand (and known desity) for engine & trans?
Jon
