87 5 speed into 88
  • TimbyMaTombo
    • Jul 2012
    • 413
    87 5 speed into 88
    Hey everyone, I might be purchasing the parts I need for a 5 speed swap into my 88 325is from an 87 325i convertible that is being parted out locally. Although I am pretty sure on what is needed and stuff, I just wanted to ask the board a few things. Is the 87 considered an early model, therefore having a different Center Support Bearing? Also, I know there are plenty of lists of the parts needed fo the swap, but I was wondering which hoses and lines do I need and where do they come from? I'm sure there will be another thread by me later when I start the actual swap, but for now, I'm just acquiring parts and want to make sure I get them all.
    Thanks!
    Peter
  • illest318i
    • 1472
    Yes an '87 is an early model... that is all
    IG: @_j.wn
      • 37829
      All of the parts from the 87 convertible will work. You will need to swap to a late model center support bearing but the rest will be exactly the same. Get the clutch master and slave along with the hard and soft lines for them. Get the pedals, shifter setup, and the driveshaft.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • jeffnhiscars
        • Jun 2011
        • 6010
        Trans support bracket as well.
        Alice the Time Capsule
        • TimbyMaTombo
          • Jul 2012
          • 413
          Alright, thanks. Would I be correct in assuming the lines are attached to the master and slave, so they should be easy to find, follow, and remove?
            • 37829
            Yup!
            Grover Beach, CA
            www.BimmerHeads.com
            • TimbyMaTombo
              • Jul 2012
              • 413
              I should be picking up the transmission and all related parts this Friday! The person I'm buying them from says I'd be able to fit them in my trunk, but I'm not sure I want to risk that...
                • 37829
                You can easily fit them in the trunk of an E30. The driveshaft even fits without separating the halves.
                Grover Beach, CA
                www.BimmerHeads.com
                • TimbyMaTombo
                  • Jul 2012
                  • 413
                  Well that's convenient! I was thinking I could take out the back seat and put cardboard and towels down so it might be a little easier, but I may just put it in the trunk, then!
