So I may or may not need to replace the transmission in my recently acquired '91 318is. Has an issue shifting into 4th gear above 45mph or so. Have been informed that fixing this via a rebuild is a serious PITFA and that it would be easier to simply grab a different transmission. With that in mind, do I have any options beyond the same unit? Any options from other series (E36 maybe?) that won't require a ton of massaging to fit? And so on.
TIA,
fastgeek
TIA,
fastgeek
