Which manual transmission fluid in 325ic?
  • jaydeep
    • Jun 2011
    • 208
    I need to change manual transmission fluid in my 1992 325ic. What type of fluid should I use. My owners manual says SAE 80 so SAE 80W-90 will work?
    I am also changing differential fluid with 75W-90. Is that correct fluid?
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • stamar
    • Apr 2011
    • 1362
    well let me first say
    going back to your previous thread
    That your car takes 20 50 not 5 30.
    And I recomend 15-50 mobil 1 full synthetic even for a summer only vehicle.
    for your transmission you have a green sticker.
    for a getrag with 59k miles only I would only use redline mt 90
    for the differential use gl5 75w-90
    • Thizzelle
      • 4422
      I use shockproof in my cars.
      Lightweight for diff
      heavy for gearbox
      "I wanna see da boat movie"
      "I got a tree on my house"
      • reelizmpro
        • 9543
        When I first got my m3 the diff whined so I used shockproof 80w-140 and the noises went away. I just use regular mtl in the trans. I'm worried if I go too thick it will be too notchy when cold.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • CarsSuck
          • Oct 2005
          • 968
          I have Redline MTL in the trans and 75w-90 in the differential.
          --Will
          • stamar
            • Apr 2011
            • 1362
            I dont think he has the same transmission as you two do that take mtl.
            He has the later model green sticker that wants 75-90
            for the diff I use mobil 1 80-140 but 75-90 is fine.
