Busted LSD
  • OTT
    • 83
    Busted LSD
    Awhile back I broke my small case lsd. I needed the car back on the road so I put in an open small. I just got around to inspecting it and found that my spider gears were in a pile at the bottom of my diff case... I think the clutch packs locked, stressing the spider gears that eventually gave but I haven't taken the LSD apart to know for sure.
    Does anyone know if open diff spiders will fit in an lsd? I'd like to just get a new set of clutch packs and gears if possible... if not does anyone have a LSD unit for sale?
  • SkiFree
    • Jun 2011
    • 2766
    Spider gears between the small open and small lsd are not interchangeable.
    You're reasoning behind the failure is sound, a locked clutch plate means you got essentially a fully-locked diff with all that stress going straight to the gears. It'd be interesting to crack the case and see what caused the perma-lock.
    BMW still lists LSD components for the E21 small case, but I believe the clutch plates and dog-eared plates have a different ID between the E21 and E30 (will varify with my notes tomorrow).
    ADAMS Autosport
    • OTT
      • 83
      Maybe I can order e21 gears and porsche clutch packs... maybe.
      • SpeicherBimmer
        • Apr 2012
        • 365
        how did you figure that out? This is Patrick, BTW
        sigpic'87 335i
        • Wanganstyle
          • 2828
          the small case LSD units usually shear the left side bearing surface. remove the side caps (4 bolts) and drop out the center unit to see the carnage
          • OTT
            • 83
            I'll post pictures
            • SkiFree
              • Jun 2011
              • 2766
              The number of teeth on the friction plate are different from E21 to E30. The spider gear that the out-put flange slides into on the E21 has a shorter neck for the clutches to slide onto.
              EDIT: as a side note could you snap a picture of the pumpkin top cover for me?
              ADAMS Autosport
              • TobyB
                • 5298
                However, you CAN stick an E21 carrier into an E30 small case...
                ...you'll just (probably) lose your speedo.
                t
                • Eric
                  • 5142
                  Why not source a medium case LSD?
                  • OTT
                    • 83
                    They're all like 500€ over here and a med case is to heavy to ship APO... Any ideas? I need a 3.15-3.45.
