dual masss clutch on single mass flywheel ?
  • chris_rai
    • Sep 2009
    • 99
    anybody ever tried this ? the dual mass pressure plate is a lot lighter !! will it works ?
  • cabriodster87
    • Jan 2011
    • 1042
    I would say, no.
    Reich und Roll!
    • bubbajan21
      • 1962
      It will likely chatter pretty badly since it would be a single mass flywheel with a solid hub clutch. I would say bad idea.
      • chris_rai
        • Sep 2009
        • 99
        maybe using a sprung clutch disc with the dual mass pressure plate ?
        • TobyB
          • 5298
          Oh, they're not that different- it'd probably work just fine.
          If you wanted to do it right, you'd re- step the solid
          flywheel to the same as the dual mass...
          But I hate dropping the trans, so I'm not about to try it.
          t
