Transmission oil listing
  • stamper
    • Apr 2011
    • 25
    I am changing the manual transmission oil in my 91 318i. I haven't found and information does anyone know which oil I should use?
  • 5Toes
    • 9836
    tractor oil. I am serious
    • Vivek
      attention whore/retard/bitch
      • 6167
      75w90 synthetic. Brand is basically up to you and what you wanna spend. Everyone will recommend redline.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • stamper
        • Apr 2011
        • 25
        Thanks
        • bastianshaw
          • Jan 2007
          • 2210
          yep redline
          • e34john
            • Apr 2006
            • 3599
            Originally posted by 5Toes
            You linked us to a thread where 1 guy uses it?
            OP, Like almost everyone else on here I use Redline.
              • 37834
              Please do not listen to the recommendation for gear oil, your transmission uses ATF.
              Grover Beach, California
              BimmerHeads.com
              • Smelser
                • Feb 2011
                • 633
                turbo tech 2000 ATF costs about 2 bucks a litre at wally mart
                sigpic1984 318i Total conversion to a DIRT race car.
                Check out our build on facebook @ www.facebook.com/brewstermotorsports
                • Smelser
                  • Feb 2011
                  • 633
                  the tractor oil he is referring to, maybe what is also called TDH. Its a newer oil based for tractors more so in the cold northern climates.
                  it stands for transmission differential hydralic
                  it can be used in the hydralic system with no problems and is "thin enough" in the cold climates to be used in tractors diffs and trans that normally get 80w90 or 85w140.
                  might be worth a try, try mixing half TDH and half ATF
                  You make your own fluid called ATDHF!!
