late 318i half-shafts vs 325 half-shafts
  • Cyrix2k
    • 593
    Are the half-shafts in a '91 318i different than a 325i/e as far as strength? I have a 24v swapped '91 318i that's soon to see a turbo and want to make sure nothing blows up. The small case diff will be replaced with the 2.79 medium case from my 325e. Thanks!
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
  • b*saint
    • 3794
    The flanges are different if you have a small case diff.
    Ma che cazzo state dicendo? :|
    • Holland
      • Nov 2008
      • 7212
      Flanges have nothing to do with it. And I'm pretty sure all late model axles are the same. It's 85 and earlier you have to worry about.
      Originally posted by DEV0 E30
      • Cyrix2k
        • 593
        From what I heard, the axles bolt right up to a medium case - the axle flanges stick out on the small case to make up for the smaller dimensions.
        Can you elaborate on the "85 and earlier" problems? My goal is to swap an '85 325e non-abs diff into a '91 318i abs car. I'd like to install the 4.10 from the '91 in the '85 too, but I might buy a more suitable diff. I'm pulling the go fast parts off the '85 and putting them on the '91 which has a good body and interior, then selling the '85 as a running 24v beater.
        1997 540i/6 - stock
          • 37829
          Yes, late 318 axles are the same as all 325i/is/ic cars.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • irish44j
            • 2763
            I have an '85 318i with small case, and I am using axles from a later ABS car. I don't recall having to change anything.....
            Stage rally/rallycross e30 build/competition journal
            Track/street e21 build
            visit Condor Speed Shop
            visit Motorsport Hardware
            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
            • jeffnhiscars
              • Jun 2011
              • 6011
              The early non-ABS cars will be missing the ABS sensor ring so while the shaft will fit in your 91, your ABS will not work as it should.
              Typically you have to knock the ABS ring off to get it to fit in the early non-ABS hub as they are shaped differently.
              Alice the Time Capsule
              • Cyrix2k
                • 593
                wait, is an ABS ring/sensor integrated into the diff??? I just want to swap the diffs, not the axles. I'd prefer to keep ABS, but I guess it's not that big of a deal if it doesn't work. LSD > ABS.
                1997 540i/6 - stock
                  The ABS speed sensor rings are on the half shafts. The differential has nothing to do with ABS.
                  • Holland
                    • Nov 2008
                    • 7212
                    This. OP will have zero issues swapping diffs.
                    I have 85 325 trailing arms in my 318, and I got a set of ABS axles a while back. While I thought all I had to do was remove the ABS ring, I found out that the splined end was an entirely different shape and would contact the inside of the trailing arm. The later axle was a square shape, and the recess in the trailing arm was a rounded shape.
                    • irish44j
                      • 2763
                      you're right....but I'm also using 325i later hubs/LCAs so didn't have to :)
