m20 to m20
  • ahalfacre5
    • Aug 2012
    • 156
    m20 to m20
    I swapping the tranny over outside of the car.. do I still need a clutch alignment tool... and I mean NEED im 100% broke
    1986 325es
  • nickflic3
    • Sep 2009
    • 3564
    Yes
    Maybe borrow one?
    Cammed B25 Swap Daily Driver
    Updated 10/1
    • ahalfacre5
      • Aug 2012
      • 156
      1986 325es
      • JCarp90
        • Feb 2011
        • 1759
        I did mine without one. I got lucky and only took me 2 stabs. My buddy's was a total bitch. Just depends.
        • slammin.e28
          שמע ישראל
          • 12054
          I've never been able to get it without using the tool, and then it was still a bitch.
          • MAXELHOFF
            • Jan 2008
            • 414
            Do you have sight?
            No. Just make sure the clutch disk stays centered on the pilot bearing as you tighten the pressure plate.
            grain of salt:p
            http://https://youtu.be/H8gOAzYchAE:ot:
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5604
              Easier said then done.
              • TurboJake
                • 3780
                Fun fact, the E30's wheel lug makes a great clutch alignment tool. I used an extended lug to do it under a car once. Stabbed on first try.
                Leave Me Transaction Feedback
                • TobyB
                  • 5296
                  It's easy.
                  But if you're not taking the clutch off the m20 you're using, it's COMPLETELY unnecessary.
                  If you ARE taking the clutch off, just center the plate by feel off the pressure plate-
                  snug the pressure plate just enough to hold the friction plate in place, then
                  center it up using just the tips of your fingers.
                  Your fingers can tell when the friction plate's an equal distance from the pressure plate,
                  then tighten it a bit more and recheck.
                  It's EASIER to use the tool, but even the tool's not foolproof.
                  t
                  • Den_k321
                    • 1248
                    take a smallest 3ft-6ft extension, slide one side into pilot bearing and in the middle put lots of electric take on, evenly. there is your alignment tool
                    1988 325is S50 in-progress.
                    http://www.facebook.com/E30LocalCrew
                    Few pictures:
                    http://www.r3vlimited.com/board/showthread.php?t=255061
                    • ZekeTheSneak
                      • 1562
                      you dont need one. eyeball it. I have never used one
