Need Help with Drive Shaft (pics Included)
  • e30forlife
    • Mar 2012
    • 583
    For an e30 1990 325ix
    Installing the rear drive shaft this weekend. I am a bit confused on one thing though. I kinda remember loosening something up but now that im looking at it there is no way I can reach something in their.
    Does this tighten up? If so I cant get anything down their too....
    Here is a pic straight on...
    Now if im right I just tighten up the 4 bolts on the back to the drive shaft/diff.. And front goes to the output of the transfer case with the flex disc.
    Is this correct?
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
  • camip
    • Nov 2011
    • 1253
    You need the center support bearing in there too. Also there is a lock ring that should be loosened when put on and tightened when installed. This picture shows both. The lock ring is on the side that the splines go in to.
    • e30forlife
      • Mar 2012
      • 583
      Remember my car is a ix. It doesnt have a support bearing. Its actually 1 piece. If you look at my pictures you will see the nut all the way down there. I think its suppose to be exposed or extend the driveshaft. I just cant make it happen.
      Any suggestions on how or had this problem?
      91 318 s52 Swap
      -m50 manifold
      -headers
      -zf320
      -3.25lsd
      -KaMotors Intake
      • camip
        • Nov 2011
        • 1253
        Shit never messed with an Ix so I'm no help there. Try the ix sub forum.
        • e30forlife
          • Mar 2012
          • 583
          In garage. Any help would be great....
          91 318 s52 Swap
          -m50 manifold
          -headers
          -zf320
          -3.25lsd
          -KaMotors Intake
