will the e90 shifter work with the e30 or even fit? and will the e60 short shifter kit is rogue. i wanted to see what you guys think or if someone has already done this before?
e90 short shifter vs e60 short shifter kit
Tags: None
will the e90 shifter work with the e30 or even fit? and will the e60 short shifter kit is rogue. i wanted to see what you guys think or if someone has already done this before?sigpic
most guys arent gonna spend money on an e90 shifter for a test. plus waht do u mean by the e60 shifter is rogue?
if you have one, u should just try it. but i dont belive it will fit, the hole where the selector rod is smaller i believe.1989 325i SETA stroker [delphin] R3V'd 8/31/2011
1989 325ix [zinnoberrot] $OLD
1970 2002 [Nevada]
Originally posted by Herr Faust Schinkenguy must have slid into something that doesn't look like a car vs car hitOriginally posted by ak-Must of slid into RobComment
