Replacing Driveshaft - Suggestions for breaking Diff End nuts free?
  • MDVDuber
    • Apr 2011
    • 69
    I've been PB Blasting it for 2 weeks now, and I just can't get them to break free. Any suggestions would be most welcome.
  • reelizmpro
    • 9559
    Wedge large breaker bar in the U joint (or E brake) to keep the shaft from turning. Then use 2 wrenches together for leverage to break the nuts free. Piece of cake.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Jaxx_
      • Dec 2009
      • 1880
      using the ebrake usually works for me. and if you want something better than PB blaster... 1:1 mix of ATF and Acetone.
      • FLG
        • Sep 2011
        • 3165
        Atf and kerosene works good
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • MDVDuber
          • Apr 2011
          • 69
          Thanks folks - Back to the Garage...
          • enigmaticdream
            • Jan 2010
            • 572
            6 point 17mm wrench and a BFH worked for me. Make sure parking brake is engaged and car is in gear
            1986 911 Supercharged Frakenstrat/Stripped
            1987 325is Delphin/Black (Olga)
            1988 M3 Zinno/Natur (Elsa)
            Manual or STFU
            E30 Chapter of BMW Car Club of America
            E30 Oktoberfest 2017
