flywheel question
  • Dirty325ix
    • Sep 2012
    • 689
    flywheel question
    On a auto transmission there is a spacer and triangle piece of metal In between The flywheel in the engine...Is this the same on a manual flywheel
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    No, the triangle piece is not used on a manual flywheel. The spacer or the bolts are not shared iirc.
    -Andy
    • Dirty325ix
      • Sep 2012
      • 689
      So I bolted the fly wheel straight to the crankshaft that was right
      right
      That would be good news
        • 37834
        No, you bolt the flywheel straight to the crankshaft.
        There is a round washer/plate/spacer that goes between the bolts and the flywheel though.
        Grover Beach, California
        BimmerHeads.com
        • Dirty325ix
          • Sep 2012
          • 689
          Sorry for the stupid questions I am just assembling a 5 speed swap and have never seen it taken apart and the fly wheel diagram on realoem is the same from auto to manual
          can I use the thin circular metal plate that was with the auto or should I buy this
