I have 02/86 325E parts car. Pulled the 2.7 E engine and transmission to take the 5 speed for a swap. Was surprised that the flywheel is a single mass-was expecting dual.
The tranny is Getrag 260.1270.90 with sensors and with late model shifter mounts on the back top (even though it had an early shifter). This would mean it's a late model E 260 tranny.
I want to swap it into an auto (10/88) 89 325iC. This E flywheel has enough meat on it to be resurfaced. I want to make sure that in this little E's previous life someone hasn't swapped in something weird.
I'm looking at a 21211223102 Sachs clutch kit hoping that it will all fit. The distance from the outer edge of the Bell Housing to the flange of the slave cylinder is 6-7/8ā which implies an early E transmission with a deep bell housing (maybe Iām not measuring in the right place because a late Getrag E should be 6-1/2ā).
My questions are:
1. Are all Single Mass flywheels the same if they are on a 2.7 or 2.5 with at Getrag 260?
2. If yes, will the 21211223102 Sachs clutch kit work?
3. Could this possibly be a Getrag 260 late model with a deep housing?
4. If it is a deep housing then would a 21511204525 30mm throw-out bearing correct the deep problem?
Most of my info has come from this post:
Thanks
My questions are:
Thanks
