Shift lever and selector rod Q's...
  • B2ThaZiZza
    • Aug 2004
    • 614
    Ok well I have a 91 318is with the stock getrag 240 tranny(is this right?).My question is i have an e30 M3 selector rod which is shorter than my stock one, can I use ane e36 M3 lever. If I remember one shift lever needs to be bent but if I used as shorter selector rod combined with a bent lever would it be able to work?
  • B2ThaZiZza
    • Aug 2004
    • 614
    Bumpity bump bump, Bumpity bump bump
    • Digitalwave
      is a poseur
      • 6292
      Way to wait 9 minutes before bumping it asshole.
      You are confused. The lever is longer, therefore shorter throws. That means you have to bend the selector rod (not the lever) so it doesn't hit the harmonic balancer. That is on a 325i at least, I am not sure if its the same on M42's.
      RISING EDGE
      • kowalski
        • Jan 2005
        • 1791
        no no bending required on the m42.
