z3 1.9 and dssr harmonic balancer
  • bastianshaw
    • Jan 2007
    • 2210
    so my z3 lever SLIGHTLY rubs in reverse and a tiny bit in second will this be better the same or worse if i install a dssr?
  • E30_fiend
    • Apr 2006
    • 7348
    Worse, simply because they are thicker in diameter than the stock selector rod.
    I wouldn't do it if I were you.
    Taylor
    • reelizmpro
      • 9558
      Depends on which way your selector rod is facing.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • FARZAD
        • 257
        I have the same issue and trying to figure out what to do?
        • bastianshaw
          • Jan 2007
          • 2210
          here
