how do i get this off
  • bastianshaw
    • Jan 2007
    • 2210
    is this my vibration damper?
    im installing a dssr
    i found a thread in e30tech talking about using a 30mm thinwall on the transmission side but why would i need to do that?
    I've not seen one like that before, but to get it off the studs will need to be pushed out (and replaced with bolts), the CSB removed, and the balancer slid off.
    • seatown88
      • 331
      +1 The studs will need to be pressed, or hit out. The CSB does not need to be removed however, the cutouts in the vibration damper with allow it to slide over the driveshaft flange
      • bastianshaw
        • Jan 2007
        • 2210
        This is a vibration damper right?
        this is disconcerting...
        • bimmer630
          • 1228
          the 30mm socket they speak of is for removing the nut that holds the driveshaft flange on the trans output shaft
          • bastianshaw
            • Jan 2007
            • 2210
            right i dont see how that applies here
            • Danny
              • 14216
              Tap the studs out with a hammer and then pull the vibration dampener off. You can replace with studs again, or use bolts. I used bolts. Mine looked the exact same.
              • bastianshaw
                • Jan 2007
                • 2210
                danny do you remember the specs on the bolts?
                • Danny
                  • 14216
                  The torque specs? No I don't, not off the top of my head.
                  • 36brua
                    • 689
                    I had same set up. use a large hammer. drive bolts out.
                    They are knurled so it might take a couple of whacks. Tossed dampener in recycle
                    I bought new bolts from a fastener supply house. I'm not sure of the part #'s listed
                    The flex disk bolts are 54mm long if they clamp a vibration damper, and 50mm without. They are grade 10.9, so you won't find them at the corner store.
                    26-11-1-209-498 Hex bolt, M10x50mm 10.9, now 26-11-1-225-054, $2.42/1.94
                    26-11-1-225-744 Hex bolt, M10x54 10.9-PHR 4.68/3.74
                    Bolts can be reused if they are straight and haven't stretched (check that a new non-locking M10 nut spins freely). The self-locking nuts should always be replaced.
                    07-12-9-964-672 Self-locking hex nut for flex disk and diff, M10, 6@, $0.25
                    My CA legal M60 swap
                    The happening in our garage
                    • Regnar75
                      • Sep 2011
                      • 483
                      is there any negative effects to removing this dampener? its there for a reason isnt it?
                      • long tall eta
                        • Jul 2010
                        • 1536
                        your right, it is there for a reason but nobody can seem to come up with it.
                        • FLG
                          • Sep 2011
                          • 3165
                          Removed mine and have no issues at all.
                          Sent from my Galaxy Nexus using Tapatalk 2
                          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                          • bastianshaw
                            • Jan 2007
                            • 2210
                            ok got it off didnt have to drop csb just hammer bolts out
                            regarding the damper
                            my guess is its there to increase rotational mass to help smooth out shifts kinda like a little flywheel
                            thoughts?
