OK so I have a 86 325es that I'm swapping a 87 325i motor into.
1) will my drive shaft work with this as long as I use the same transmission?
2) I need a CSB, did they make ones specific to the 325e drive shaft?
3) I need a guibo, on my trans it has the weird vibration damper thing where the guibo meets to the trans, so does that mean I need the small diameter guibo?
4) when I change my CSB should I paint my drive shaft so the splines go back the right way?
I just wanted some clarification before I do this stuff
