M52 swap - driveshaft center support bearing need shimmed down?
  • Cynical 1
    • Nov 2012
    • 129
    had a vibration issue and replaced my guibo on my 88 e30 with M52/G260.
    i noticed that the PO had shimmed the center support bearing down about 1/4 inch using some washers.
    is this necessary?
    car is using the green engine mounts, and has the correct swap trans mount.
    again - do i need to shim the center bearing down, or should i remove them?
    1988 325 "super ETA" - Hilde - M52B28 swapped...
    1969 2002 - Griselda - 20VT AWP swap and full resto in progress...
    project blog - http://www.cynicalmotorsport.blogspot.com/
    • 37833
    I haven't shimmed it on any of the swapped cars I've been involved with.
    Grover Beach, California
    BimmerHeads.com
    • Cynical 1
      • Nov 2012
      • 129
      thanks. it looked kind of hokey and i removed it.
