Drift differential welded?
  • martin318ise30
    • 128
    Hellow r3v, just wondering if anybody knew where or how to weld a diff for drifting. So I opened the diff but not really sure what to weld. To be specific im welding a 4.10 diff. Thanks in advance.
  • kojack
    • Aug 2011
    • 44
    You want to weld the spider gears together so that essentially both axles are locked together
    Heres a good example;
    • martin318ise30
      • 128
      Ok thanks a lot for the example pic. That looks like its gonna take a whole spool of wire. Lol. Anyways. My rear end dont really look like that . I think I have a cover over the spider gears. Im sure a can take that cover off. I hope.
      • SkiFree
        • Jun 2011
        • 2766
        Uhm.... pic? Do you have an LSD center?
        ADAMS Autosport
        • Simple_Smith
          • Aug 2011
          • 585
          Sounds like he has an LSD assuming he pulled the diff from the car in his username.
          1989 JDM-Tech 2
          2010 335 D for daily
          • BenjaminButtton
            • May 2012
            • 275
            If that's true, please don't destroy a perfectly good LSD.....
            LSD's can be rebuilt without too much trouble to increase lock-up, which would be better for drifting than a welded diff.
            This might be helpful, again assuming you have an LSD.
            Early models do it better.
            '86 Cosmos Sedan LS1
            • martin318ise30
              • 128
              Yes just found out it is lsd
              It is a 4.10 lsd but its not from my previous 318is. I just picked up a shell for really cheap and a full m42 swap with also the diff thinking it was a open 4.10. But gess not. Lol
              http://e30performance.info/viewtopic.php?f=22&t=939
              Dont worry I wont be destroying the diff specially after seeing your link. Im probably going to end up rebuilding it stronger.thanks a lot .
              • kman_e30
                • May 2007
                • 573
                lsds cant be welded
                84 318i drift car
                04 mk4 gti 1.8t
                96 e320
                63 plymouth valiant
                • BenjaminButtton
                  • May 2012
                  • 275
                  Glad to help and good luck! I found that page a while ago, I'm planning on doing the rebuild on a 3.73 myself.
                  • Wanganstyle
                    • 2828
                    If your lsd unit is a 168mm I suggest selling it and buying a 188mm lsd in same ratio to build up.
                    Bmw designed some adjustability in the 188mm lsd; the 168mm has no such design and the top cap also fractures easily. The capsule of both 168mm and 210mm have to be bored to accommodate more plates- the 188mm does not as has a dead spacer inside already.
                    Sent from my GT-N7100 using Tapatalk 2
                    • bmwman91
                      • Oct 2004
                      • 3134
                      Awesome link, thanks!
                      Good to hear that you will be doing it the "right" way!
                      How can one tell if an LSD has the 168mm or 188mm (part?) design? I assume that the 168mm. 188mm and 210mm ones you mention are the small, medium and large case diff's?
                      Transaction Feedback: LINK
                      • Wanganstyle
                        • 2828
                        Post a photo and we can all ID it
