Shift Selector Shaft Seal - Help please!
  • BimmerHeadBri
    • Oct 2004
    • 48
    Ok, I have searched all the archives and someone mentioned to lower the rear of the tranny to change the Shift Selector Shaft Seal. I changed it a while ago (but did it wrong - it didn't sit right and is leaking worse than before) but I also was changing the CSB and guibo, so I had the exhaust and the driveshaft off.
    Now I really don't want to take all that crap off again to change this stupid little seal. I like the idea of lowering the rear of the tranny, but not sure how much is safe, ie. before I break something.
    Anyone have any thoughts on this?
    Oh, and one more thing, what can I use to make sure the seal does not leak? I am pretty certain where it sits is now scored by the tweaked seal and will leak again even with a new one. Is there a sealant I can apply once the new seal is in to make sure I NEVER have to do this again?
    Cheers.
    Brian in Calgary
    '86 325e
    '81 528i
    BimmerheadBri
    '86 325 (eta)
  • AdamF 88iS
    • 2051
    Did you scour the selector shaft or the tranny housing? If it's the housing you can silicon it. If you scoured the shaft you're SOL.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • BimmerHeadBri
      • Oct 2004
      • 48
      I'm pretty sure I only scored the tranny housing.
      So what, just regular silicone after I put the seal in?
      Thanks.
      BimmerheadBri
      '86 325 (eta)
      • AdamF 88iS
        • 2051
        Get a small dab of silicon on the housing first so it fills the mark in when you pop the seal in.
        Adam Fogg- '88 M3
        • BimmerHeadBri
          • Oct 2004
          • 48
          Thanks Adam
          Appreciate the advice. Now I just have to find the time to do it.
          Cheers.
          BimmerheadBri
          '86 325 (eta)
          • bootlegskate
            • Jun 2010
            • 139
            for future searchers:
            DD '03 AW M3
            • jeffnhiscars
              • Jun 2011
              • 6011
              Personally, I keep silicon away from anything that has gears, bearings and oil passages since bits of it do and will wander, it never breaks down and the damage it can do can be catastrophic ( I feel the same about RTV).
              For seals use anaerobic gasket sealer (Permatex makes some) on the outer rim and if at all possible don't drive the new seal to the same depth as the old one so the lip rides on a fresh surface.
              Note to self...check dates of thread before posting :)
              Alice the Time Capsule
