3.91 lsd from a 1984 work in my 91 318is?!? help guys
  • bsturman92
    • Sep 2012
    • 282
    Hey so i came across a 3.91 lsd from a 1984 e30... will it fit.my 91 with no problems? Or do i have to swap out the flanges??? Im going in a few hours to pick it up so i would appreciate any help..... thanks guys
  • Bearmw
    • 1323
    It's a good diff for your car but I can't remember if the flanges need swapping. It is also a good performance upgrade for a basically stock 325i as well IMO.
    • reelizmpro
      • 9556
      It should fit but it's a small case diff with the long flanges. No need to swap the flanges, if you do then they will be too short, IIRC. I'm not sure but I think your 91 has the medium case diff like the 325's.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
        • 37833
        It's a direct swap. You'll just need to change over your speed sensor.
        Barry the 84-85 318 and 91 318 both had small case diffs.
        Grover Beach, California
        BimmerHeads.com
        • Boltspeedman
          • Mar 2012
          • 207
          sorry to jump in on this old thread, but since on the topic I figured I'd ask a couple questions..
          I'm debating on 4.10 or 3.91 lsd in to my 318is, currently has a 4.10 open. As far as performance, Am I loosing any acceleration with a 3.91 vs. 4.10? I know at this point either would be an upgrade.
          • ELVA164
            • 4861
            You will lose a little acceleration, but it will also help you on the highway. A fair trade in my opinion.
            • drummerchubbs
              • 512
              Will 1991 325i directly work with a medium case 2.93LSD???
              SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
              • reelizmpro
                • 9556
                Yes, they all will work. It's just a matter of size difference. small case diffs will have longer flanges.
                88 M3 - LACHSSILBER
