318ic differential case question?
  • Beemerdan
    • Nov 2012
    • 192
    I found a really good deal in oem limited slip differential parts out of a 91 325ic that I would like to put in my 91 318ic. It says it will not fit the small case differential. So my question is: Does my car have a small case differential, or is it the same as the 325ic?
    Thanks!
    Dan
    • 37833
    All 318 E30s have the small case diff.
    Grover Beach, California
    BimmerHeads.com
    • jeffnhiscars
      • Jun 2011
      • 6011
      I do believe you can swap to a medium case as long as you have the output flanges to go with it and you dont mind the extra weight
      Alice the Time Capsule
        • 37833
        Yes the medium case diff would be a direct swap.
        BimmerHeads.com
