PLEASE EXCUSE THE NOOB QUESTIONS ITS MY FIRST MANUAL E30
Issue 1.
My clutch pedal falls over night and i have to pump it.
Can I just rebuild the slave? or am I better off to just buy new?
Is there any way to check fluid?
Issue 2. Gearbox feels stiff when cold, also feels notchy, I was told to try out some Redline fluid, but which one? what weight?
Issue 3. The trans sounded a bit whiny but there was no shifter boots rubber or otherwise, now that they are on it sounds better, Should I worry about a slight whine?
Issue 3. My shifter is looser than a dancing girl, am I better to just freshen it up or just do a short shift kit? I believe I have to pull the skid plate to do either?
Car is a 87 325i 4 door manual. build date of 12/86
Issue 1.
