Inverted torx bolt attemping to strip with assictans
  • jwiles
    • Jun 2012
    • 200
    Are their any good tecniques to get off the inverted torx bits at the top of the bell housing, the tech I used last time( long as extension and breaker bar to ratchet/ ratcheting breaker bar) is working but this one bolt on the pass. side is being a real *%^CH, could really use the help ive heard it go off like a .22 but for some reason i cant get the thing to budge. ive tried coming from the back:D and the middle but i just cant seem to get it to turn any and its even casuing the breaker bar to flex, the extinson is close to 2 ft give or take 3:6 inches.
    hell idk sometimes you just have to wing it. JW
  • Boise
    • 212
    What is an "assictans"
    • jwiles
      • Jun 2012
      • 200
      assistance
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        36" extension 3/8's to 1/2" w/ swivel and a 1/2's rattlegun.
        • Chriskbmx
          • Apr 2012
          • 972
          sounds like you need yourself an impact gun, atleast a decent one. aircat makes decent airguns for a good price.
          • 997_rich
            • Feb 2013
            • 48
            When you use an impact gun you really want to try to minimize the universals and adpters if you can.
            • Chriskbmx
              • Apr 2012
              • 972
              this is very true, but i think you would be better off using a few extensions to get your extra leee way then to use any kind of universal joint
              • kronus
                • Apr 2008
                • 13032
                If you can get a ratchet from the top, between the head and the firewall, use a deadblow on the end of the ratchet.
                cars beep boop
                • Danny
                  • 14216
                  Don't use a dead blow. Use a box end wrench on the end of the ratchet or a cheater pipe to gain more leverage.
                  • bmwstudent
                    • Sep 2011
                    • 1364
                    cuss at it a lot, make it feel bad about itself. Leave and come back later and you will be successful.
                    • ELVA164
                      • 4861
                      This works more often than you would think.
