600+ hp in e30. what rear end
  • blusylver
    • Feb 2013
    • 230
    I'm looking upgrade the rear end prior to destroying it. What is the best option? Anyone have first hand experience?
  • Good & Tight
    • Apr 2004
    • 2057
    Your half shafts will fail first before the diff. One option is replacing the rear end with the Mcoupe trailing arms and 1/2 shafts. they bolt right into your stock diff and subframe.
    There is a 210mm diff out of a 5 series not sure which one but a lot of drag cars use them.
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • travish325
      • Jun 2012
      • 1151
      Your car has 600hp?
      • Skunkworks
        • Sep 2012
        • 436
        Pics or it didn't happen....
        • blusylver
          • Feb 2013
          • 230
          I'll get pics soon. Its a built ls1 with a pro charger on 11 lbs of boost.
          It had 596 whp on 10 lbs stock heads and a decent cam. Now its ported and polished, bigger valves and a bigger cam
          • blusylver
            • Feb 2013
            • 230
            Anyone running aftermarket half shafts??
            I'm looking into having a camaro or ford 9" rear end shortened..
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Currie.
              • blusylver
                • Feb 2013
                • 230
                That's kind of my last resort. Thanks though
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Have you seen bender's thread with the Viper center section and C4 Vette setup?
                  • LJ851
                    • 7918
                    PPF in Sweden will make you custom "flex steel" half shafts to your dimensions, they are rated for 1000 plus HP i believe.
                    Lorin
                    The M30 is God's engine.
                    • blusylver
                      • Feb 2013
                      • 230
                      No I haven't, I'll look it up. Thanks
                      I was just reading about PPF about 20 min ago
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        Here, in case you didn't find it.
                        • Wanganstyle
                          • 2828
                          I can build you a rear end for 500-1000rwhp if you have the axels/stubs that can take it. Dss would be my recommendation as many locals are running them happily.
                          Twin ear rear cover is also needed from garrets kit for lsx e30 or e36m rogue cover. E30 single ear unit will not take 600rwhp!! The thin cast alu is prone to cracking/snapping off in drag racing and road racing.
                          210mm diff is not needed although will last for more passes- 188mm built diff took 35 passes in the 9's@1krwhp before clutches wore- gears and bearings were still good to race more.
                          A few locals with my units:
                          Ls7 e36m
                          Ls3 e30m
                          S50 drag turbo e36m @4b motorsports (1,000rwhp sias tuned -9.1@159 on IRS before going to tube rear)
                          • Madhatter
                            • Oct 2004
                            • 966
                            The DSS axles are amazing. I literally flipped out when I opened the package. They are probably 4 times the weight of the stock ones, massive cv's, just screams quality.
                            In our ongoing quest for the perfection, we have hit the mark with our 1986-1992 BMW E30 700HP Level 5 Direct Bolt-In Axles (Pair)
                            Great quality, but high cost. Depends on the budget.
                            Just a little project im working on
                            - http://www.lse30.com -
                            • kristov
                              • 222
                              Are they still holding up?
